Gudgeon pin circlips - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Gudgeon pin circlips (/showthread.php?tid=6040) |
Gudgeon pin circlips - RossV - 30-04-2021 I have just opened the box containing a 060 piston etc. The gudgeon pin is ground for the little end bolt but there are two circlips in the box. Should they be used as well as the clamping bolt. V RE: Gudgeon pin circlips - Colin Reed - 30-04-2021 HI Rossv No RE: Gudgeon pin circlips - Chris KC - 30-04-2021 The circlips are for use with fully floating gudgeon pins. RE: Gudgeon pin circlips - Bob Culver - 30-04-2021 The gudgeons must be readily moveable in the pistons; tight ones a cuase of pinch bolt failure. RE: Gudgeon pin circlips - RossV - 01-05-2021 Thanks. I can move on to the next stage of assembly now. The Forum is a fabulous way of sharing knowledge. Many thanks to the Minder(s). |
