sealing the oil pump bottom plate - Printable Version
+--- Thread: sealing the oil pump bottom plate (/showthread.php?tid=6002)
sealing the oil pump bottom plate - jamesheath - 23-04-2021
Hi All,
Hopefully an easy one - should there be anything at all sealing the bottom plate of the oil pump?
I don't think there's a paper gasket, but a wipe of Blue Hylomar? (I don't want to get any on the vanes....)
RE: sealing the oil pump bottom plate - Steve Jones - 23-04-2021
No. Metal to metal.
RE: sealing the oil pump bottom plate - dickie65 - 23-04-2021
I usually take any scoring out of the baseplate with a sheet of wet and dry lubricated with paraffin then clean out and smear it all with oil on assembly.
