valve chest cover I.D - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: valve chest cover I.D (/showthread.php?tid=5973) |
valve chest cover I.D - womble 36 - 18-04-2021 Good morning, recently bought this alloy chest cover and just wondering who could have made it. It has a space for (presumably) a makers plate but has no rivet holes. Does anyone have any idea or recognise it please. Many thanks for any (polite) suggestions, Charlie. RE: valve chest cover I.D - Lowespeed - 18-04-2021 Looks like a "Supaloy" valve chest cover to me. I cast one and machined the letters off to put my own lable on it with plastic casting letters; then cast it in Aluminium. Maybe someone did the same to have a plain cover RE: valve chest cover I.D - Steve kay - 18-04-2021 Oh dear, no name and no evident provenance. Sadly it can hardly be worth ten bob. However, if you’d like me to put a pound note into an envelope and post it off to you....... RE: valve chest cover I.D - "Slack Alice" Simon - 18-04-2021 Am I right in thinking it is drilled to fit an early block? The later ones have holes that are in the middle? RE: valve chest cover I.D - AustinWood - 18-04-2021 I think those holes are in the middle. There is space left to drill the holes for early block. RE: valve chest cover I.D - "Slack Alice" Simon - 19-04-2021 Ah, yes. Now I see there are different numbers of lines top and bottom. RE: valve chest cover I.D - Colin Wilks - 19-04-2021 Assuming you intend using it, it is worth checking for straightness before fitting. Mine was about 4mm bowed, meaning the outer ends didn't put much pressure on the gasket. I flattened it by taping some emery to an old granite worktop, reckoning it was better to sacrifice a little bit of meat for the sake of a perfect fit from the off. RE: valve chest cover I.D - John Mason - 19-04-2021 Steve, Showing your age now talking about 10 Bob and 1 pound notes. They were the days when you could have a night at the cinema followed by a fish and chip supper and still had change from a pound. John Mason. RE: valve chest cover I.D - womble 36 - 20-04-2021 Just a note to say many thanks for the info to those who replied. Steve - checked post box. still no nicker in it. Colin - thanks for tip, will check for flatness and deck it if needed. John - no cinema but remember going for lunch in my 2nd year of Litho apprenticeship (1971) Pint of mild and bitter 2/5d and next door to chippy for cod and chips 2/6d. Anyone got a time machine please? Regards Charlie. |
