1934 rp deluxe sunroof - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 1934 rp deluxe sunroof (/showthread.php?tid=5941) |
1934 rp deluxe sunroof - sparkimark - 12-04-2021 Hi All, finally getting round to the restoration of my 34 RP. Mechanically been done , but now needs the body doing, not looking forward to this! My issue is i'm unsure what the sunroof wood should look like. I think I have all the wood parts, not sure how they go together. Has anyone out there got any good pics that they are willing to share to help me out Thank you in advance RE: 1934 rp deluxe sunroof - Martin Prior - 12-04-2021 We (Martin Prior and Son's Motor Works) build, supply and fit all sunroof parts for all A7 models. I'd be happy to talk you through the fitting operation and confirm whether you have everything that you need. Please call me on 01432 820680, or email buildingsbespoke@btinternet.com. RE: 1934 rp deluxe sunroof - sparkimark - 12-04-2021 Thanks Martin, i'll be in touch regards Mark RE: 1934 rp deluxe sunroof - Hugh Barnes - 12-04-2021 The archive is your friend - at least to give you an idea of assembly http://archive.a7ca.org/collections/technical-drawings/item/TD0190/? Hugh RE: 1934 rp deluxe sunroof - Ivor Hawkins - 12-04-2021 And if you use Martin’s beautifully cut timber, the framework should look something like this... RE: 1934 rp deluxe sunroof - Martin Prior - 12-04-2021 Thanks, Ivor! However, just to avoid confusion, Ivor's track set is leaning up against the wall and is not yet fitted to the roof! RE: 1934 rp deluxe sunroof - Ivor Hawkins - 12-04-2021 Absolutely right Martin, here's one with the tracks and the vinyl installed at the rear! RE: 1934 rp deluxe sunroof - Geoff101 - 14-04-2021 Martin's wood on my frame: |
