Temperature Gauge - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Temperature Gauge (/showthread.php?tid=5875) |
Temperature Gauge - Barry Townsend - 29-03-2021 Does any else get erratic readings from their Boyce gauge. On my RN the readings were all over the show despite me having done the thermostat mod suggested on this site. To cure the apparent problem I've extended the probe with a short piece of 10mm copper tubing as I suspected that the probe wasn't actually in the coolant once the system got going. The logic of the copper is that it has good heat transfer properties and 'voila' I now get a steady reading in keeping with the cars usage and the thermostat is doing a grand job of a quick warm up and consistent temperatures. Boosted by this flush of success I went a stage farther and made up a vented coolant container out of sight behind the front number plate into which the overflow pipe goes, a la modern cars, meaning that the coolant level will pretty much look after itself now and stay topped up. I really must have a lie down now, the excitement is getting too much. RE: Temperature Gauge - "Slack Alice" Simon - 29-03-2021 The coolant will only look after itself if you have a sealed (and therefore pressurised) system. Modern cars work because, as they cool, the closed system creates a vacuum which sucks the excess water back into the radiator. (So I believe) I'm afraid you will have to pour the tank contents back in yourself. RE: Temperature Gauge - Terrytuned - 29-03-2021 No loss water system RE: Temperature Gauge - Barry Townsend - 29-03-2021 The system is actually sealed inasmuch as the overflow pipe is immersed in coolant and with the natural expansion and contraction of the system it sorts itself out so far - as long as the rad cap is sealing all appears to be ok Great minds think alike - mine is more akin to your early model ! RE: Temperature Gauge - Hedd_Jones - 29-03-2021 If you've had a seven long enough, you figure out that it will find its own level, somewhere when cold where the coolant level is just above the core. So long as you have no leaks or a calamity occurs, thats where it needs to be. My check is take the cap off. Coolant visible. Good to go. No coolant, the bastard has a leek RE: Temperature Gauge - Steve kay - 29-03-2021 Typical Salopian joke that. RE: Temperature Gauge - Ian McGowan - 29-03-2021 Hedd ain't wrong though, Steve! He's just never overcome the Welsh Leek for Leak. |
