Ruby MK1 pinion shaft thread - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby MK1 pinion shaft thread (/showthread.php?tid=5797) |
Ruby MK1 pinion shaft thread - darcher121 - 15-03-2021 Would anyone have the correct thread size for the pinion shaft of the torque tube? I now have the pinion flange off but the shaft thread is damaged. So I will need a replacement nut as well as a correct die to recut the shaft thread. Thanks! RE: Ruby MK1 pinion shaft thread - Bob Culver - 15-03-2021 refer Pinion Nut post above. |
