1932 Austin 7 Brakes juddering when in reverse. - Printable Version
+--- Thread: 1932 Austin 7 Brakes juddering when in reverse. (/showthread.php?tid=567)
1932 Austin 7 Brakes juddering when in reverse. - Smiley - 19-12-2017
Hi , is there anyone out there who has experienced brakes grabbing/Juddering when braking in reverse (on a slope for instance). Anybody got a cure.?  Thanks.
RE: 1932 Austin 7 Brakes juddering when in reverse. - Ruairidh Dunford - 19-12-2017
Something is most likely loose or worn Smiley.
Brake pivot, radius bolt, worn brake cams, shackle pins. Try putting the handbrake on and rock the car firmly, look to see what is moving.
RE: 1932 Austin 7 Brakes juddering when in reverse. - Nigel was in Brittany - 19-12-2017
I had the same on my RN , took the drums off ,blew the dust out ,cured ! .
RE: 1932 Austin 7 Brakes juddering when in reverse. - Rick F - 20-12-2017
My RP does it. I always put it down to the front axle flexing, tightening the cable and pulling the brakes on harder.
RE: 1932 Austin 7 Brakes juddering when in reverse. - Ruairidh Dunford - 20-12-2017
Nigel and Rick, I too have suffered both these as cause.
The dust one always perplexes me, what is happening in reverse that does not happen onward?
