1936 Nippy: Where is reverse? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 1936 Nippy: Where is reverse? (/showthread.php?tid=5651) |
1936 Nippy: Where is reverse? - Spencer - 10-02-2021 Greetings from the newbie on the block. My late father’s most treasured possession was his 1936 Nippy. Rather than sell it I have decided to take it over. The car is in South Africa but I shall ship it to Australia. I have managed to start it and go for a drive, but I cannot find reverse! All positions on the H are forward gears. Can anyone tell me where reverse is? Also, what petrol should I use? Is unleaded a problem? Thanks in advance. Spencer. RE: 1936 Nippy: Where is reverse? - Dave Prior - 10-02-2021 Unleaded is fine, it's what they were originally designed to run on. For reverse, you need to lift the stick (pull up) and then it's right and down. RE: 1936 Nippy: Where is reverse? - Peter Arnold - 10-02-2021 Nice to see another 7 come to Australia. RE: 1936 Nippy: Where is reverse? - JonE - 10-02-2021 have you come across the https://aus7in.wordpress.com Nippy archive, Spencer? It would be good to know if your car is 'known' about, especially if its particularly original. RE: 1936 Nippy: Where is reverse? - Greig Smith - 10-02-2021 Where is the Nippy in SA Spencer, I'm in PE if you need anything done before it leaves ?? Ciao Greig RE: 1936 Nippy: Where is reverse? - wild_willy - 11-02-2021 Unleaded 98 is the only fuel to use here in Oz the rest is rubbish. In which state will the Nippy reside? A warm welcome to Australia. RE: 1936 Nippy: Where is reverse? - Spencer - 12-02-2021 Thank you! Easy when you know how. My partner doesn't have to push me backwards, and is grateful! RE: 1936 Nippy: Where is reverse? - Spencer - 12-02-2021 @JonE. Thanks for the link. I shall certainly look to see our car has any known history. I know my Dad had her for about 18 years but do not know who he bought it from, and so have no 'inherited' knowledge. @Peter Arnold. Thanks for the welcome. I still have to get the Nippy there. Have been living abroad, but will return to Bargara/Bundy eventually. I see you are in Qld. Whereabouts? @Greig Smith: I am just down the road in Plett. Thank you for the offer. I will PM you if I need help. @wild_willy: Thanks for the welcome. The Nippy will languish in sunny Qld for the time being. |
