Early dipstick - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Early dipstick (/showthread.php?tid=5614) |
Early dipstick - Douglas Alderson - 01-02-2021 As we are posting about dipsticks, I though I would add this to the mix. I came across the two early dipsticks, they are both unmodified and judging by age look original but as you will see in the photo different length above an below the fill line, I did ask in our local club if any one new why, but no answers. Any thoughts? RE: Early dipstick - Steve Jones - 01-02-2021 I've got a pair of dip sticks identical to these. The longer on started out longer at the oily end as well but I shortened it to suit. I assumed it had originally come from a bigger Austin. Heavy Twelve perhaps? Steve RE: Early dipstick - Parazine - 01-02-2021 The short one looks like it came from a magneto engine, the long one from a 28 - 31 coil engine, although all my dipsticks, mag or coil are the same measurement from bottom to "full". Interestingly, they appear in the spares book for 1927 and 1929 as BA49, so interchangeable? RE: Early dipstick - Tony Press - 01-02-2021 I would think the critical bit is the bottom measure. The short one would be difficult to pull out with an oily knob - ooh Matron ! RE: Early dipstick - Parazine - 02-02-2021 Indeed Tony, the whole oil check and addition process is challenging on Mag engines! ![]() |
