Timing cam in situ - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Timing cam in situ (/showthread.php?tid=5521) Pages:
1
2
Timing cam in situ - tomcotez - 13-01-2021 Is it possible to time a new cam with the crankcase already in the chassis? It looks possibly to fit a smallish timing wheel on the crank gear at the front. The reason for this is that I am waiting for a cam to arrive and could get on and bolt other bits together, set up clutch etc without losing too much time. Is there a minimum diameter for an accurate timing wheel? RE: Timing cam in situ - Zetomagneto - 13-01-2021 Bigger timing wheel is more accurate, worth the wait I would say. Do you have an adjustable cam gear, if not how do you propose getting it spot on. All easier on the bench. RE: Timing cam in situ - Ncoates - 14-01-2021 why not rebuild the gearbox or back axle whilst you're waiting.... RE: Timing cam in situ - tomcotez - 14-01-2021 not sure I'd still be married after that. I'm already in trouble for putting degreaser down the sink and heating up flywheel in the oven... I have a stepped key, was going to play with that on the cam or crank gear, but may have to get an adjustable gear if that doesn't work. RE: Timing cam in situ - Charles P - 14-01-2021 (14-01-2021, 12:12 PM)tomcotez Wrote: not sure I'd still be married after that. I'm already in trouble for putting degreaser down the sink and heating up flywheel in the oven... I heat treated a silver silver steel cutter on the shelf below a pizza last week. However the flywheel ring gear was done when I knew that I wouldn't be disturbed/discovered. c RE: Timing cam in situ - Hedd_Jones - 14-01-2021 I work on the principle that I paid for and installed the cooker/dishwasher/freezer/fridge so I'll do whatever I like with them. Last night I had a Halfords ratchet spanner warming gently on the gas, I've just bought it in a set and it appears that it had been put away damp and was stuck. A little heat and a bolt in the vice and it came free quite easily. No heat and plus gas had no effect. RE: Timing cam in situ - Reckless Rat - 14-01-2021 (14-01-2021, 04:07 PM)Hedd_Jones Wrote: I work on the principle that I paid for and installed the cooker/dishwasher/freezer/fridge so I'll do whatever I like with them. To take a line from the film "Ben Hur".... - Bravely spoken! RE: Timing cam in situ - Renaud - 14-01-2021 Yes, but try that line on my wife... All those interesting marital considerations won't much help Tom to time his camshaft though! RE: Timing cam in situ - tomcotez - 14-01-2021 Pie wheel RE: Timing cam in situ - Charles P - 14-01-2021 (14-01-2021, 07:02 PM)tomcotez Wrote: Pie wheel Is that to try and bolt it on whilst still hot? What torque did you use? c |
