Catching noise when braking - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Catching noise when braking (/showthread.php?tid=5469) |
Catching noise when braking - morrisminor - 30-12-2020 If I brake gently I can hear catching I think from the rear, with each rotation of the wheel, if I brake firmly it doesn't seem to do it ? Any ideas everyone ? RE: Catching noise when braking - Charles Levien - 30-12-2020 (30-12-2020, 05:17 PM)morrisminor Wrote: If I brake gently I can hear catching I think from the rear, with each rotation of the wheel, if I brake firmly it doesn't seem to do it ? Any ideas everyone ? Stick to braking firmly RE: Catching noise when braking - David Stepney - 30-12-2020 Check that the rear wheel nuts are firmly nipped up. I had a similar problem that turned out to be slack wheel nuts! RE: Catching noise when braking - Chris KC - 31-12-2020 Not sure what you mean by 'catching' but most likely your drums are slightly oval such that under light pressure they only contact with the shoes twice per revolution. A7 drums are so lightly constructed that skimming them is liable to make matters worse. Drum distortion may also be induced if the joint faces are not quite flat - again I would not remove metal but it may be worth checking for obvious high spots and distortion in the joint. To some extent the above is inherent in the A7's 'lightweight' design and may be hard to eliminate altogether. RE: Catching noise when braking - "Slack Alice" Simon - 31-12-2020 Probably just some minor mis-alignment of the brake shoes. But the answer to your question prompts a reminder about something that should be done regularly: before checking wheel nuts, have the wheels off and check the half shaft nuts. I have left off the wheel centre trims (so I don't need to take the wheels off) , and I don't fit the split pins, and every month or so I put a socket on the nuts, with a long extension to a ratchet spanner, support the outside end on an axle stand, and then stand on the end of the spanner handle. That keeps them tight and helps avoid more serious problems later. RE: Catching noise when braking - morrisminor - 31-12-2020 Thanks Slack, I don't get a clonk when moving off which I'm lead to believe is indicative of not tight half shaft nuts ? Worth a try though. So you leave the wheel on to tighten and car on ground ? Sorry what do you put on an axle stand ? RE: Catching noise when braking - Howard Wright - 31-12-2020 Hi Morrisminor Make sure the back plates have not be knocked in to the drum. On pre Girling cars the back plates are quite flimsy and are often quite badly dented. Jack the car up and try spinning the wheel with the brake cable slack and then pulled up slightly. Cheers Howard |
