58mm pistons - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: 58mm pistons (/showthread.php?tid=546) |
58mm pistons - Zetomagneto - 08-12-2017 Went to collect my block from boring today, unfortunately it didn't clean up at .060" and will apparently need liners, or bore to .080". I preference the latter, does anyone have a set of 58mm pistons they would like to sell, or trade for a new unused set of .060" pistons . Tony is out of 58mm and I don't want to spend £220 on a set from one of our other cherished suppliers before exploring other possibilities. I do have another block at .020" but don't want to bore that to .060" it would be a waste of good metal RE: .080" pistons - Hugh Barnes - 09-12-2017 Well, the Workshop has a complete range of sizes up to and including +.080 for £168 it would seem. There is always a risk associated with +.080 that the cylinder walls could be getting very thin (depending on the block casting) so be wary of that... RE: .080" pistons - Zetomagneto - 09-12-2017 (09-12-2017, 09:27 AM)Hugh Barnes Wrote: Well, the Workshop has a complete range of sizes up to and including +.080 for £168 it would seem. There is always a risk associated with +.080 that the cylinder walls could be getting very thin (depending on the block casting) so be wary of that... Hi Hugh Thanks for response, I do buy from Jamie. His largest oversize is .080" 58mm = .083" I need that extra .003" to get rid of some light rust pitting. I could run his Pistons with extra clearance but not ideal. RE: 58mm pistons - Zetomagneto - 27-03-2018 Still looking for some 58mm slipper pistons anyone please |
