Box saloon - Printable Version
+--- Thread: Box saloon (/showthread.php?tid=5422)
Box saloon - Djackson - 20-12-2020
Hi Looking for a Box saloon body in reasonable conditions. Maybe someone has a disregarded body around they need to clear up . Hi
RE: Box saloon - Dave Wortley - 21-12-2020
No responses yet. You may get a better response if you gave everyone more details. For example are you in the process of rebuilding a Seven or do you require the body for a different purpose?
Also, there is a “Sales and Wants” section for you to use. I hope that helps you.
RE: Box saloon - Djackson - 21-12-2020
Hi looking for a Austin Box saloon to restore or look at converting to a van I have a very good chassis engine etc I am not interested in the Ulsters looking for something different to put on a chassis . Looking to build a car I can use on a regular basis .
RE: Box saloon - David Stepney - 21-12-2020
Have you got a long (6ft 9in wheelbase) or short (6ft 3in) chassis?. There are a couple of threads on the forum showing the building of bodies that are not open sports. The Highland Special is one such.
RE: Box saloon - Chris KC - 21-12-2020
Yes 1st step is to ID which bodies your chassis would be compatible with - principally LWB or SWB.
I would suggest keeping an eye on eBay as they come up from time to time in restorable condition. Usually when someone has ripped an original saloon body off to build a 'special'.
RE: Box saloon - Martin Prior - 21-12-2020
Can I suggest that you see if there's anyone out there with a complete saloon that they're planning to dismantle in order to build a special? If you can agree a PX for the entire vehicle against your rolling chassis, it keeps another car intact and gives the special builder less to do.
RE: Box saloon - Zetomagneto - 21-12-2020
All box saloons are LWB afik, request is box saloon body, so must be LWB?
Are not RMs box saloons, then?
RE: Box saloon - Reckless Rat - 21-12-2020
PM me with your e-mail address. I know someone who is scrapping an RN to make a special.
I have photos to give you an idea:
[Image: IMG-20201101-WA0001.jpg]
You will have some travelling to do because it's in France, near Paris.
I am aware of this car . With the present restrictions and recovery costs I was looking for a car in the UK
