Ruby/Pearl Door Cards - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby/Pearl Door Cards (/showthread.php?tid=5421) Pages:
1
2
Ruby/Pearl Door Cards - John Cornforth - 20-12-2020 Hi I am thinking of replacing the (already replaced once) door cards of my early Pearl. I assume the originals were 1/8 inch plywood. Any recommendations for the best material to use ? Is it a good idea to treat the wood with anything ? Whilst the cards are off, has anyone found a modern replacement for the little rubber roller that sits against and guides the window glass ? RE: Ruby/Pearl Door Cards - Martin Prior - 20-12-2020 John, we can supply the cards. Please pm me if you'd like any details. RE: Ruby/Pearl Door Cards - Peter Naulls - 20-12-2020 I'd be interested to hear more about the little roller John. Our windows rattle when open, perhaps because they should have one. Mk1 or Mk2 ? RE: Ruby/Pearl Door Cards - Martin Prior - 20-12-2020 The rollers are only fitted to the Mk1, Peter. I can probably sort out a photo, if you're interested. RE: Ruby/Pearl Door Cards - Peter Naulls - 21-12-2020 Thank you Martin. Mine is a Mk2 so not applicable. The rattle is obviously a feature! RE: Ruby/Pearl Door Cards - Dennis Nicholas - 22-12-2020 Back in the day all accessory shops sold little rubber wedges that you could put between glass and door top. Prevented rattle and stoped windows gradually opening themselves when mechanisms worn. RE: Ruby/Pearl Door Cards - Malcolm Parker - 22-12-2020 Regarding windows rattling, I think that Austin addressed this problem. On my SWB RL saloon the top rail of the window lining incorporates a detail which stops the window rattling and pushes the glass outwards against the felt lined channel when closed. On the inside angle of the rebate of the timber there is a length of rubber tubing about 1/4" diameter ( similar to that you would find in the Chemistry lab at school). The leathercloth or fabric covering goes over this. As the glass reaches the top of its travel, the top edge is gently pushed out by the cushioned corner of the rebate. I suspect that when cars have been restored this detail might have been overlooked. Similarly there is a length of cloth covered piping between the door frame top and the window top rail. I think there was also a small valance of cloth above the door to prevent a draught, this was fitted between the edge of the head-lining and the decorative braid used to hide the tacks. These little details make the difference, I think a saloon needs to be comfortable! RE: Ruby/Pearl Door Cards - Geoff Halstead - 22-12-2020 My Ruby ARQ. Am thinking of using a row of ‘O’ rings. RE: Ruby/Pearl Door Cards - Nick Lettington - 22-12-2020 (22-12-2020, 01:36 PM)Geoff Halstead Wrote: My Ruby ARQ.What is the diameter of the rollers Geoff? I bought some gas tube from a plumbers merchant that I believe comes in various sizes... RE: Ruby/Pearl Door Cards - andrew34ruby - 22-12-2020 Don't remember the rollers on mine, and it's only a few months since I put the doors back together. How do you ever hear the rattle of the windows with all the other racket going on? |
