compression pressures - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: compression pressures (/showthread.php?tid=5399) |
compression pressures - Barry Townsend - 14-12-2020 I was wondering what the cylinder pressures should be on my 1931 RN Currently they are all about 50psi which seems a little on the low side I'm in the process of doing a decoke/valve job amongst other tidying up jobs. The bores look perfect and unless I'm very mistaken the pistons look relatively new RE: compression pressures - Chris KC - 14-12-2020 Not sure about low comp heads but I think you should aspire to at least 50% more than that. Apologies, but have you followed the instructions with the gauge? Otherwise you may not be reading correctly. RE: compression pressures - Bob Culver - 14-12-2020 Throttle should be open.Compression on Sevens is easily assessed on the handle. Can compare with others, although so many have raised cr it often confusing.. Should have a degree of bounce. 50 is low. RE: compression pressures - Barry Townsend - 14-12-2020 Hi Chris Thanks for your reply, that's about what common sense and experience suggested to me. I wouldn't expect much more from a low comp engine - BTW I've used the gauge on numerous occasions over many years including building several high performance engines, I am a retired mechanic but relatively new to Austin 7's which are still a mystery! Kind regards Barry T RE: compression pressures - Reckless Rat - 14-12-2020 I would have thought that 90psi is about right for a LC engine in good fettle. You DO have to do the test with the throttle wide open (and spark plugs removed) RE: compression pressures - Chris KC - 14-12-2020 ...and engine thoroughly warmed... RE: compression pressures - John Mason - 14-12-2020 Barry have you done the oil down the spark plug holes then done a second test to see if compression is being lost down past the rings rather than burnt or bad seating valves. John Mason. RE: compression pressures - dickie65 - 14-12-2020 I usually do a compression test with the engine running. Its a bit naughty to cause a deliberate missfire and then rev the engine though, ( I have a Billet crank so less of a risk for me ) Its about time I gave it another check !! |
