Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(287) : eval()'d code PHP 8.1.29 (Linux)
Chummy Windscreen Information. - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Chummy Windscreen Information. (/showthread.php?tid=5347) Pages:
1
2
Chummy Windscreen Information. - Robert Foreman - 02-12-2020 Would some kind soul be able to take some windscreen measurements for me please. I would like to know the size of the of the steel side iron section for the screen, preferably measured with a micrometer. Also the dimensions of the lower screen channel and the thickness of the glass. Finally maybe a photo of the lower screen corner. RE: Chummy Windscreen Information. - Tony Griffiths - 02-12-2020 Might these help? RE: Chummy Windscreen Information. - David.H - 03-12-2020 I suggest that all these measurements "in the day" would have been to the nearest sixteenth or thirty second part of an inch.... David RE: Chummy Windscreen Information. - Robert Foreman - 03-12-2020 Thanks for the photos Tony. What year of car is it? Any measurements for the bottom half of the screen sections would be greatly appreciated. RE: Chummy Windscreen Information. - Parazine - 03-12-2020 I think the glass was 1/4" plate glass or triplex laminated if you paid extra. The laminated became a compulsory retrofit sometime in the early 'thirties I believe. RE: Chummy Windscreen Information. - Tony Griffiths - 03-12-2020 (03-12-2020, 10:24 AM)Robert Foreman Wrote: Thanks for the photos Tony. What year of car is it?It's a Chummy registered in February 1929. Here are some from an October 1930 Chummy. Is there anything specific you would like? RE: Chummy Windscreen Information. - Robert Foreman - 05-12-2020 Thanks for the information Tony, Looks like the screen channel is a nominal ½"x⅝". Now where to source some? Can your friend give us the other dimension for the side iron please? RE: Chummy Windscreen Information. - Tony Griffiths - 06-12-2020 (05-12-2020, 09:17 PM)Robert Foreman Wrote: Thanks for the information Tony,A pleasure, glad to help. My "friend" accompanied "myself" to the garage where I and we measured the other dimension of the 1930 Chummy's windscreen upright as follows (we both agreed with ourselves and each other that it was cold out there): RE: Chummy Windscreen Information. - Robert Foreman - 06-12-2020 Thanks Tony, I didn't realise that you have two chummies including your schizophrenic friend. Does anyone know of a supplier for the ½"x⅝" brass section? RE: Chummy Windscreen Information. - Tony Griffiths - 06-12-2020 (06-12-2020, 08:41 PM)Robert Foreman Wrote: Thanks Tony,Any other data you need, just let me know and I'll measure it for you. |
