Does the Trades Description Act cover EU traders? - Printable Version
+--- Thread: Does the Trades Description Act cover EU traders? (/showthread.php?tid=5308)
Pages: 1 2
Does the Trades Description Act cover EU traders? - Mike Costigan - 25-11-2020
I suspect not, although I'm surprised the EU doesn't have some similar control over traders. This thread has been prompted by this advert from a Dutch trader; I know it's not an Austin, but nor is it "in almost completely original condition". The 'woody' rear body is a bit of a giveaway, but just in case that doesn't convince you, how about the Triumph TR6 engine under the bonnet!
https://www.prewarcar.com/315491-1934-morris-ten-six-special
.jpg   315491-1606316685-9029460.jpg (Size: 119.19 KB / Downloads: 430)
RE: Does the Trades Description Act cover EU traders? - John Mason - 25-11-2020
I don’t know about original but that wooden rear end is abominable. Spoils the whole look.
John Mason.i
RE: Does the Trades Description Act cover EU traders? - Stuart Giles - 25-11-2020
I wonder what happened to the original rear of the body, can't imagine that anyone would just take it into their mind to create a sports tourer with a rear end that looks like it came off a shooting brake.
BTW, If that motor is from a TR6, then it must have been the US spec model which had Stromberg CD carbs in place of the Tecalemit Jackson fuel injection of the European models.
I wonder if still has the original brakes? Cry
RE: Does the Trades Description Act cover EU traders? - JonE - 25-11-2020
not cheap either! Pity while they were on the woodwork they couldn't have attended to the veneer on the dash - or is it just deep figuring in the walnut?
RE: Does the Trades Description Act cover EU traders? - Steve kay - 25-11-2020
In the Netherlands and not Germany, so not a single leather satchel. Rich patination enhanced by a delaminating plywood dash panel, will this catch on amongst certain sorts of poser? And is it just me or does it have a central accelerator?
RE: Does the Trades Description Act cover EU traders? - Mike Costigan - 25-11-2020
Yes, Steve, all Morrises had a central accelerator up to the mid-thirties, but I suppose it's a surprise it wasn't converted when the Triumph engine was fitted.
Thanks Mike, I knew Cowleys did,  but I did not know that the hungry beast, the Morris 8, had a centre loud pedal.
RE: Does the Trades Description Act cover EU traders? - Mike Costigan - 26-11-2020
Steve I'm not sure about the Eight; the last of the Minors had a central throttle, but the Eight may have been the first to have a conventional layout.
RE: Does the Trades Description Act cover EU traders? - Chris Garner - 26-11-2020
The Morris 8 pedal layout was conventional.
RE: Does the Trades Description Act cover EU traders? - Greig Smith - 26-11-2020
I would surmise that the TR6 engine would allow you to get to the scene of the accident a little faster than the original oily bits
Aye
Greig
