NIPPY/65 WHEEL ARCH. - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: NIPPY/65 WHEEL ARCH. (/showthread.php?tid=5297) |
NIPPY/65 WHEEL ARCH. - Rpm - 23-11-2020 Hi all, maybe a dumb question but, Why do the wheel arches on these 7s vary so much, particularly the front, which seems to be very high even historically from the factory. The Nippy / 65 look so much better from a side view with less wheel on display. anyone achieved a little less on their cars. My own car is not bad probably factory high but would like less on the front. Stay Safe, shouldn't be long now before we can get back to socialising again. Regards Rob. RE: NIPPY/65 WHEEL ARCH. - Lance Sheldrick - 23-11-2020 The 65 which I had a few years ago (DG 7171) looked like that because the front spring was flat rather than with negative camber. It had been changed at sometime and looked wrong in my opinion. RE: NIPPY/65 WHEEL ARCH. - Chris KC - 23-11-2020 I've just finished reconstructing the wired edges on mine where the tyres have worn completely through them. Better a tad too high in my opinion! RE: NIPPY/65 WHEEL ARCH. - Chris Garner - 23-11-2020 As Lance states the aspect of the car is very dependant on the set of the front springs. I'm happy with my 65! RE: NIPPY/65 WHEEL ARCH. - Rpm - 23-11-2020 So all down to spring Neg/Pos then, some are very high. although can see what you are saying Chris. RE: NIPPY/65 WHEEL ARCH. - Chris Garner - 23-11-2020 I should have said " spring " in the singular! Your exhaust system is looking low...and vulnerable, rpm. RE: NIPPY/65 WHEEL ARCH. - JonE - 23-11-2020 https://aus7in.wordpress.com/2018/11/17/rear-wing-type-position-and-fit/ going back to Austin idealised drawing, how does front crest sit with rear apex? They want to be the same (otherwise it will look the same as so many ulsteroids that appear to slope backwards on the road because the back of the cockpit is lower than the front) RE: NIPPY/65 WHEEL ARCH. - Rpm - 23-11-2020 That's True Jon, I have seen a few that way, and that's not a good look either. A good sitting car stands out immediately. Hey Chris, I'm hoping to address the exhaust downpipe in the new year, I currently have a horrible Flexi pipe. RE: NIPPY/65 WHEEL ARCH. - Zetomagneto - 23-11-2020 The Blockley tyres are also a slightly smaller dia than other 350 x 19 tyres. Having said that I like the Blockleys and although they don't have a great deal of tread they areĀ good value IMHO |
