Zenith 26JS - 3 Carburettor - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Zenith 26JS - 3 Carburettor (/showthread.php?tid=5106) |
Zenith 26JS - 3 Carburettor - Tod - 19-10-2020 Hi, I have a Zenith 26JS - 3 Carburettor which appears to be in very good condition. It is from an Austin A30 803cc engine. I intend to use it on my special with a "Nippy" inlet manifold. Does anyone have experience with this set up. I am wondering what jet changes, if any may be required. The general specifications are, Choke, 18mm --Main Jet, 95 --Main Air Jet, 160 --Slow Running Jet, 40 --Slow Running Air Bleec, 40 Tod RE: Zenith 26JS - 3 Carburettor - Ian Williams - 19-10-2020 I don't have experience of that particular carb but I have successfully run Zenith 30V carbs of various types such as used Big 7's and 8's amongst others. You probably will need different jetting, what you have may be a bit rich. RE: Zenith 26JS - 3 Carburettor - Dave Wortley - 20-10-2020 I have a Zenith downdraught with 26mm choke on my RN saloon. I would try it as it is and get new jets if running rich. Can't remember jet sizes as it's 17 years since I fitted it. Mine has a home made tubular inlet and exhaust manifold. Car pulls and revs well, better than the side mounted 26 VA. RE: Zenith 26JS - 3 Carburettor - Dave Wortley - 20-10-2020 Just looked at carb on my RN. It is 26 VME which has nominal bore of 26mm and looks to be 18mm choke. RE: Zenith 26JS - 3 Carburettor - Tod - 21-10-2020 Many thanks for the replies and advice. I have contacted Burlen for jets. Tod |
