Inside a newly-acquired engine - Printable Version
+--- Thread: Inside a newly-acquired engine (/showthread.php?tid=5101)
Pages: 1 2 3
Inside a newly-acquired engine - Tony Griffiths - 18-10-2020
Your comments, please, on the inside of this engine and its contents. It's been a "while" since I had one apart and your expert eyes would be appreciated. I don't know how many miles it's run, but the sump had a layer of gooey sediment - and I didn't want to start it until I'd checked for such things.  If you click on each picture, there's a higher resolution copy - and click again for a close-up.
RE: Inside a newly-acquired engine - Zetomagneto - 18-10-2020
Phoenix crank, lucky you! Oil residue doesn’t look particularly dirty. 1 conrod not central in piston, but as long as there is a gap no worries.
Picture of sump contents ?
RE: Inside a newly-acquired engine - Tony Griffiths - 18-10-2020
Thanks. Invoices show "new crank and rods". Are the rods Phoenix as well? Here's the sump...
RE: Inside a newly-acquired engine - Steve Jones - 18-10-2020
Phoenix crank, Austin rods, bores look good from what can be seen. I stripped my old hill climb engine last week and it looked just like this inside although the sump only had a thin film of residue in the bottom. Worth running a magnet through the sump contents and I'd check the big ends for signs of wear or breaking up.
Phoenix rods look like this.
RE: Inside a newly-acquired engine - Charles P - 18-10-2020
The sludge is only worth worrying about if it returns under controlled conditions. You don't know how this has been stored or used.
C
RE: Inside a newly-acquired engine - Alan - 18-10-2020
Rods appear to be Austin originals. No worries about that if it’s for a road engine. Is that silvery debris in the sump? If so I’d have a look at the big ends.
Is the sludge ferrous, could be iron dust from the rings/bores.
If your not sure about the engine I would happily take it off your hands!
To be honest I would whip the caps off, if all looks good put it back together and use.
RE: Inside a newly-acquired engine - Ruairidh Dunford - 18-10-2020
Hi Tony,
good to see there are some nice surprises as well.
Almost all the Phoenix shafts I have used, have "Phoenix" cast onto the side of the webs - JB cranks are machined on the sides and some later ones look identical to Phoenix except this feature.
Solid skirt pistons - JP I suspect, look for a machine dimple in the top to confirm. There were issues with these seizing in the past - this may have been resolved.
The camshaft appears to have a had a fresh grind as well.
Thank you - most helpful.
Thank you - most helpful. I'll do as you suggest.
Thank you - most helpful. I'll check further.
Just checked the sump oil with a very powerful magnet from a hard drive, and it picked up nothing at all. Hovering it over the sump gunge and it collected quite a lot - so it appears that anything harmful has settled out? I strongly suspect that the car has been standing for some time.
