3 bearing pressure fed engine - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Sales (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: 3 bearing pressure fed engine (/showthread.php?tid=51) |
3 bearing pressure fed engine - awentsbury - 10-08-2017 I have a 3 bearing pressure fed engine to sell , it came with my nippy many years ago . The engine is stripped down , I had the crankshaft crack tested and it was fine . aluminium sports sump with the 9 E cast into it , tulip valves but 3 vales are missing in the Block , Dante aluminium sports head , sports canshaft. Crankcase is un drilled where the oil jets normally go . All the bits seem to be there apart from 3 valves. White metal looks good in the con rods and crank looks fine . con rods are for floating pins . Strange that they used white metal in these engines, i thought 3 bearings would have had shells. I have kept the nippy carb , manafold and head as I am using them on my nippy. I am looking for offers over £3000.00 for this very rare engine that must be a late nippy or speedy engine. ian ian@awentsbury.com Location: Birmingham , uk RE: 3 bearing pressure fed engine - Greenwood - 05-11-2017 Hi, Is the engine still for sale? Many thanks Jonathan |
