Mag engine starter dog - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Mag engine starter dog (/showthread.php?tid=5041) |
Mag engine starter dog - Amilcar John - 07-10-2020 I'm building a mag engine from various bits and have used a Kiddie (billet) crank I bought some years ago. When fitting the timing gears, the hex on the starting dog does not abut and locate the crankshaft gear as I would expect it to, but stops short, as the thread on the dog does not extend all the way to the hex. I don't have a good assembly diagram and the exploded parts list I have shows only a lock washer in addition to the dog. How should this gear be located? Is my crank designed for the later coil starter dog? RE: Mag engine starter dog - Ruairidh Dunford - 07-10-2020 Early Phoenix cranks suffered similar - you need to remove material from the shaft, I have photos and will post when I find them. RE: Mag engine starter dog - Ruairidh Dunford - 07-10-2020 Like this... RE: Mag engine starter dog - Amilcar John - 08-10-2020 Thanks Ruairidh - as always a fast and authoritative answer! I will modify the dog accordingly. |
