Ulster Rep Front Spring - Printable Version
+--- Thread: Ulster Rep Front Spring (/showthread.php?tid=4996)
Ulster Rep Front Spring - wooster - 25-09-2020
Hi All
I was having awful handling/steering problems with my Ulster Rep. Originally the front spring was on upside down which I gather is an old trick to lower the front end. It looked great but the spring was banging against the axle and the track rod was rubbing against the chassis. It was dreadful to drive and felt very dangerous. Now I've had the spring replaced (minus 2 leaves) and put in the right way up. Wow what a difference! It drives brilliantly. But it sits so high at the front. It looks a bit daft. Anyone else had similar problems?
Rich
RE: Ulster Rep Front Spring - Zetomagneto - 25-09-2020
The spring needs to be flat, or with a slight reverse camber.
RE: Ulster Rep Front Spring - NBS - 26-09-2020
Interested to know what spring you used. Do you find the ride supple enough? Depends on what you use the car for i imagine.
RE: Ulster Rep Front Spring - wooster - 05-10-2020
What does reverse camber mean? Should the spring curve upwards or downwards in the centre?
RE: Ulster Rep Front Spring - Howard Wright - 05-10-2020
Hi Wooster
Positive camber is when the spring scowls at you, negative when it smiles. As Zeto says ideally it should be flat or slightly smiling.
