Box hinge rubber - Printable Version
+--- Thread: Box hinge rubber (/showthread.php?tid=489)
Box hinge rubber - Douglas Alderson - 24-11-2017
Can someone confirm which way up the rubber seal goes at the hinge.  The image below is from The Seven Workshop. Is the image below the right way up. Thanks
RE: Box hinge rubber - Dave Mann - 24-11-2017
The ones I got from the Seven Workshop were symmetrical, so it made no difference which way it went.
RE: Box hinge rubber - Douglas Alderson - 26-11-2017
(24-11-2017, 10:18 PM)Dave Mann Wrote: The ones I got from the Seven Workshop were symmetrical, so it made no difference which way it went.
Dave thanks, the one I took of the car was as the photo and the new one was the same, not symmetrical.  I believe it goes the way up in the photo, I guess fit and see if someone tells me I am wrong....
