Rear axle - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Rear axle (/showthread.php?tid=4766) Pages:
1
2
Rear axle - Robin Boyce - 05-08-2020 After a loud "bang" under the car, the carden pot started catching on the tunnel. The n/s axle tube had fractured about half way along, only the rear springs and halfshaft holding it all together. Age fatigue (made 1923), or any ideas? Anyone have a spare they would sell - type with bell-end stiffening ribs -? ![]() RE: Rear axle - Alan - 05-08-2020 Axle tubes weld quite nicely. I forget the size but there’s steel tube that’s a sliding fit inside the tube. Weld it in position then align the axle tube bits and weld back together. RE: Rear axle - Ivor Hawkins - 05-08-2020 Alan beat me to it, I was going to suggest exactly the same course of action, I will always do my best to save serviceable components before seeking a replacement. Many years ago I welded brackets to the axle one of my specials and remember being very impressed how well the axle welded. RE: Rear axle - Tony Griffiths - 07-08-2020 (05-08-2020, 08:29 PM)Alan Wrote: Axle tubes weld quite nicely. I forget the size but there’s steel tube that’s a sliding fit inside the tube. Weld it in position then align the axle tube bits and weld back together.Might it be a good idea to stiffen the other side at the same time, using much the same procedure? RE: Rear axle - Chris KC - 08-08-2020 It would certainly be worth having a good look around for signs of other cracks / damage. RE: Rear axle - Bob Culver - 08-08-2020 With torque tube drive, axle housing is subject to stresses, including from braking, spared the more conventional. Presumably the very early axles were lighter than later or is it common throughout? I have seen Big Seven assemblies which have been fractured. RE: Rear axle - Robin Boyce - 12-08-2020 Thanks gents, the stiffening tube and weld seems to be the answer. But guess what, I found a big box in the shed marked Rear Axle and containing a pair of the webbed tubes I need! But I will repair the broken one and hope my memory doesn't get worse. RE: Rear axle - Tony Press - 12-08-2020 (05-08-2020, 05:19 PM)Robin Boyce Wrote: After a loud "bang" under the car, the carden pot started catching on the tunnel. The n/s axle tube had fractured about half way along, only the rear springs and halfshaft holding it all together. Age fatigue (made 1923), or any ideas? Anyone have a spare they would sell - type with bell-end stiffening ribs -?I wonder if the original axle design had lighter material for the side tubes- beefed up for later production ? RE: Rear axle - Robin Boyce - 18-08-2020 Having taken the axle out I find that it has a sleeve and must have been welded before (see photo). The material looks thinner than I expected. RE: Rear axle - Stuart Giles - 18-08-2020 Is it the actual weld that's failed, or the material alongside the weld that's fractured? either way it doesn't look like the inner tube is doing anything other that aligning the axle tube. Having prepared the A7 tube's joint area with a proper "V" to ensure good penetration, I would also drill some holes around the periphery of the axle tube each side of the break and plug weld through onto the inner tube section. then weld all the way around the tube joint. Be prepared to straighten out some weld distortion once it cools down if you are using a proper amount of current for this job. |
