Fibre washer for the gearbox drain bung. - Printable Version
+--- Thread: Fibre washer for the gearbox drain bung. (/showthread.php?tid=4709)
Fibre washer for the gearbox drain bung. - John Mason - 23-07-2020
Hello all just a quick one.  Can anybody confirm that the red fibre sealing washer on a four speed gear box drain bung is the same size as for the engine sump bung.
John Mason.
RE: Fibre washer for the gearbox drain bung. - AustinWood - 23-07-2020
Yes, back axle too.
RE: Fibre washer for the gearbox drain bung. - John Mason - 23-07-2020
Thanks Jim.
John Mason
