semi-Girling drums on closed center wheels - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: semi-Girling drums on closed center wheels (/showthread.php?tid=4673) |
semi-Girling drums on closed center wheels - Erich - 16-07-2020 Hi All, My Ulster Rep has closed center wheels and semi-Girling drums. When the car was built, it had open center wheels on 17 inch rims. The owner had a set of closed center wheels built with 19 inch rims. However, he couldn't fit them due to a clearance issue. When I bought the car, Steve Hodgson was able to fit the closed center wheels. It turns out that the rears are quite a way out of round. I've found a set of new semi-Girling drums in OZ, but I am told that they won't fit the closed center wheels. Any help is appreciated. Erich in Seattle RE: semi-Girling drums on closed center wheels - Ruairidh Dunford - 16-07-2020 The outside diameter of the new drums need to be reduced until the solid centre wheels fits over them. RE: semi-Girling drums on closed center wheels - Erich - 16-07-2020 So, Ruairidh, a light turn in a lathe will address this, I assume? Erich in Seattle RE: semi-Girling drums on closed center wheels - squeak - 16-07-2020 In addition to a light external drum skim I elected to grind off the thick powder coating on the wheel hub. RE: semi-Girling drums on closed center wheels - Ian Dunford - 16-07-2020 Patience and heavy duty sandpaper may negate the necessity to acquire a lathe. |
