Fuses - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Fuses (/showthread.php?tid=4549) |
Fuses - David.H - 17-06-2020 What rating of fuse should be used in the cut out DYN & AUX? Thanks RE: Fuses - David Cochrane - 17-06-2020 I use 10A & 25A respectively. I think the DYN fuse was originally 6A, but these aren't readily available. RE: Fuses - David.H - 17-06-2020 Thank you David. I will ferret through my stock! David RE: Fuses - Colin Morgan - 18-06-2020 In case it helps, I am using 5A and 25A in my Ruby cut-out. RE: Fuses - Bob Culver - 18-06-2020 On the later cars the DYN fuse seems to protect only the summer resistor. Contray to many handbooks, and unlike earlier models, if theefuse blows dyn still works. So rating not very critical RE: Fuses - Bill Dixon - 19-06-2020 I am with Colin Morgan on this use 5amp & 25amp. |
