Missing 2 - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Missing 2 (/showthread.php?tid=4460) |
Missing 2 - morrisminor - 02-06-2020 https://youtu.be/c0PcWjEiCEw Hopefully this link will work RE: Missing 2 - Ivor Hawkins - 02-06-2020 That’s perfect, it sounds like a weak mixture to me, I would spray some brake cleaner around the carb and the intake manifold, while it’s running to see if you get a rise in revs. That would indicate an air leak. Try revving it with a touch of choke, that would also indicate a weak mixture, if you manage to get it to rev. One thing I have to ask is have you allowed the engine to warm up on the choke first? If you haven’t, this bogging down on revving is a classic symptom. If neither of these work, I’d start to look at your spark. RE: Missing 2 - Mike Costigan - 02-06-2020 Sounds like a partially blocked main jet to me. RE: Missing 2 - morrisminor - 02-06-2020 Hi guys, I've revved it gently then pulled the choke out and revved, its cleared it? |
