Zenith 22 FZB Carburettor - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Zenith 22 FZB Carburettor (/showthread.php?tid=4391) |
Zenith 22 FZB Carburettor - cwchrisp - 21-05-2020 Good Morning, Quick question regarding the 22 FZB Mazak carb. please. Where the top section joins the bottom at the slow running jet interface, is there a fibre washer, a metal washer or left open to allow air into the slow runnng jet? On the 22 FZ, there is a flap covering air holes, so my guess is the gap is left open on the 22 FZB? Many thanks. Chris RE: Zenith 22 FZB Carburettor - Dave Mann - 21-05-2020 RE: Zenith 22 FZB Carburettor - cwchrisp - 21-05-2020 Perfect, thanks so much. I am trying to patch up the cracked aluminium, I wish I had your machining skills! Chris RE: Zenith 22 FZB Carburettor - Dave Mann - 23-05-2020 1) The mazak must be 100% pure otherwise it gradually disintegrates as Meccano found with their Dinky toys 2) Previous owners loose the slow running jet retaining screw and fit an over length replacement which is over tightened jacking the side of the housing off. I've run out of the 14mm x 10 mm tube and haven't found a supplier who wants to sell me anything less than 20' RE: Zenith 22 FZB Carburettor - Tony Griffiths - 23-05-2020 (23-05-2020, 09:53 AM)Dave Mann Wrote: I had one like this on the back of my bench for years until I found a length of 14 mm OD x 10 mm Id drawn steel tube at work then the repair procedure became obvious. There are two causes of this;Any good? https://www.ebay.co.uk/c/9004859742 https://www.ebay.co.uk/itm/14MM-OD-X-10MM-ID-2MM-WALL-316-SEAMLESS-STAINLESS-STEEL-TUBE-WESTERN-EUROPEAN-/322458066256 ..and stock item 363841 https://www.pipestock.com/steel-tube RE: Zenith 22 FZB Carburettor - cwchrisp - 23-05-2020 [attachment=10208] I have a 'lockdown' project to build an FZB from bits I had and some from ebay. The top section had the same problem around the slow running tube and I used J-B Weld to patch up. I removed my FZ today and tried out the FZB and apart from the the float bowl needle seat bebing the wrong type, it seemed to work!! I had to manually top up the float bowl using the petrol tap to maintain engine running...what fun! Apologies for any errors posting as I am very new to this forum!! RE: Zenith 22 FZB Carburettor - Dave Mann - 24-05-2020 Thank you Tony. |
