Drag link cups diameter - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Drag link cups diameter (/showthread.php?tid=4386) |
Drag link cups diameter - Howard Wright - 19-05-2020 Hi All I’ve made up a new drag link 3/4” longer than standard to ensure it doesn’t go “over centre”. I measured the required extension with the steering arm vertical and the wheels straight ahead. However I thought that the internal diameter of the drag link (steering side tube in Austin parlance) was 5/8” internal diameter (3/4” outside). Unfortunately the cups don’t fit a tube reamed with a 5/8” reamer. Could someone let me know what the internal diameter of the drag link should be? Cheers Howard RE: Drag link cups diameter - Colin Wilks - 19-05-2020 I've just checked a spare cup set I have in and this measures a couple of thou less than 5/8", so I would suspect your reamer is duff! A good trick I was taught is to dip the reamer in paraffin and it will take a another cut (no idea why, but it works). RE: Drag link cups diameter - Howard Wright - 20-05-2020 Hi Colin Just an update. The cups I have are 0.627” bought from a cherished supplier (a while ago and I now cannot remember which). So just over 5/8”. So my reamer is good but the cups a couple of thou over. I have an adjustable reamer that I will use to open up the tube very slightly. The cups fit in a standard Austin tube so that must be over 5/8” diameter. Otherwise I would buy new cups and find they were oversize as well (knowing my luck)! Cheers Howard PS Thanks for the paraffin trick but like you I can’t imaging why it should work! |
