BLIC magneto parts - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: BLIC magneto parts (/showthread.php?tid=4359) |
BLIC magneto parts - Tony Betts - 11-05-2020 Help, Can anyone tell me were I can get a cap, points, and rotor arm for a blic magneto. Thanks tony. RE: BLIC magneto parts - Geoff101 - 11-05-2020 Karl at Vintage Magnetos? RE: BLIC magneto parts - Adrian Payne - 12-05-2020 Hello Tony I made up a batch of BLIC cams for Chris Gould in Bransgore, he might have some left. Were you looking for a Tufnol or steel one. If you get stuck give me a shout and I will knock one up for you. Adrian. RE: BLIC magneto parts - Robert Leigh - 12-05-2020 Donald Day may well do caps and the other bits, but he is not cheap. Robert Leigh RE: BLIC magneto parts - Tony Betts - 12-05-2020 thank you all. a couple of leads. ill give chris a call, its always good to have a chat with him. and its probably well over due to talk to him again. if not adrian, ill come back to you. its for my own projects, but i must admit. ive opened 6 blic mags in total now. and i wouldnt be happy useing any of the caps. what do others do about this, or is it a matter of the cars no longer get used? or just run poorly on what they have. thanks tony RE: BLIC magneto parts - Robert Foreman - 12-05-2020 Tony, If you come across some high speed points that are spare and a tufnol cam ring, I would be interested too. Cheers, Robert. RE: BLIC magneto parts - Tony Betts - 12-05-2020 hi robert, sorry no points. but probably have cams on a couple of the spare parts mags. tony RE: BLIC magneto parts - leaf200 - 12-05-2020 Tony, As you say caps are a general problem most of mine are well worn. I have considered making a longer rotor arm and machining the caps but never got round to it. I believe David Cockran was looking at making new caps at one point. Thanks David RE: BLIC magneto parts - Nick Turley - 13-05-2020 These people either have bits or will make them. https://www.magneto-ignition.co.uk RE: BLIC magneto parts - David Cochrane - 13-05-2020 A friend of mine looked into making caps, but it's a complicated shape and very difficult to get material that won't 'leak' the high voltage. Definitely a job for a specialist IMHO. |
