Ruby instrumentation - rubber grommets behind bezels, supplier? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby instrumentation - rubber grommets behind bezels, supplier? (/showthread.php?tid=4338) Pages:
1
2
Ruby instrumentation - rubber grommets behind bezels, supplier? - Ruairidh Dunford - 08-05-2020 Does anyone supply new rubber grommets to sit between the chrome bezels and the painted dash panel on Ruby’s please? RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - AustinWood - 08-05-2020 Would there be an 'O' ring of the right dimensions? RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - Ruairidh Dunford - 08-05-2020 Thank you Jim, I have tried these but they are too round and way too shiny - I think the originals were more like a large thin rubber washer. RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - "Slack Alice" Simon - 08-05-2020 Cut them from silicon rubber sheet? If the size is known, and enough people want them, I am sure the people who make the gaskets could do them. If you tell me a size, I can do a 1mm thick one by hand for you to try. Simon I only have terracotta colour, though. Would be worth a try maybe? RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - Peter Stanley - 08-05-2020 Hi I just did a search on "Austin 7 instrument to dash panel seals" and a number of sites came up. I got a set this way a few years ago, but haven't tried them out yet otherwise I could recommend a particular supplier. They looked Ok at the time. Regards Peter RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - AustinWood - 08-05-2020 I was thinking square section like this: https://www.ebay.co.uk/itm/293153365096 RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - Tony Griffiths - 08-05-2020 Might these suppliers have something? http://www.jdo1.com/bezels_gaskets.html Low down this page: https://www.autoelectricalspares.co.uk/bezels-glass--seals-for-smiths--lucas--jaeger-gauges-68-c.asp RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - Austin in the Shed - 09-05-2020 The sponge cord might be the right stuff that JD does.I think I have used that as the sealing ring between glass and bezel before,available in 2 or 3 mm dia.looks like o ring but much softer. Can't think of the seal suppliers name at the moment,C O H Baines is one. RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - Robert Leigh - 09-05-2020 I have been known to use a suitable rubber band. They do perish quite quickly, but it won't matter if you don't disturb them. Robert Leigh RE: Ruby instrumentation - rubber grommets behind bezels, supplier? - Bill Dixon - 09-05-2020 Ruairidh, If you go onto ebay, Video Drive Belts you will find some that will do the job. Bill retired T V Engineer. |
