Hamblin Cadet - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Hamblin Cadet (/showthread.php?tid=4267) Pages:
1
2
Hamblin Cadet - Mick Ashby - 28-04-2020 Reg No/DKO341 Chassis No/262364 Engine No/ M250216 any info would be great, RE: Hamblin Cadet - Jack in the Box - 28-04-2020 Great to see your car Mick. Welcome to Austinsevenfriends. You’ve come to the right place for help. I’m sure folk on this forum will encourage and support you with your project. Alan (Senlac Sevens) RE: Hamblin Cadet - JonE - 28-04-2020 Interesting. You should follow the 50s/60s Specials group on Facebook too, to find some other owners. What spec is it underneath the bodywork? Which bit of Sussex are you in. RE: Hamblin Cadet - Jack in the Box - 29-04-2020 Mick, I have sent you a PM (personal message). Alan RE: Hamblin Cadet - Mick Ashby - 29-04-2020 Hi thanks I will try the facebook the engine is well modified I am trying to find out exactly what has been done will try and send a photo to you see if you know anything about it. Thanks Mick Hi Alan hope yo can see the photo RE: Hamblin Cadet - Chris KC - 29-04-2020 Nice project Mick. I've never seen a distributor driven(?) like that before. The oil hose on the side looks like it was intended to incorporate a filter? By the way I have a Cadet windscreen if of any interest - not free but not expensive either - message me if interested. RE: Hamblin Cadet - Austin in the Shed - 29-04-2020 Is that oil pipe feeding oil from the front cam bush to the centre one,or the other way round ? Either way if the split centre cam bushes have been retained a lot of the oil pressure will be lost. RE: Hamblin Cadet - Chris KC - 29-04-2020 I assumed it was drilled up into the oil gallery but it's not an obvious way to do it - only one way to know for sure I think. RE: Hamblin Cadet - Jack in the Box - 29-04-2020 Chris, My understanding is that some of the owners who use their cars competitively drive the distributor directly off the camshaft to give them a wider choice of advance characteristics by using distributors from other cars. I'm sure those with more knowledge will comment more comprehensively. Alan RE: Hamblin Cadet - Mick Ashby - 29-04-2020 Hi I think the car was used for racing or hill climb I have not had the car running as it was in a sorry state when I got it. It has 12 v electric, hidrotic brakes, bowden independent front & back suspension, twin su carbs, home made inlet a & exhaust manifold, 16" wire wheels with spokes moved out. I don't know much about the car it was left in a shed for 20 years the man only drove it once it was fast he park it and was to frightened to drive it again, he got it on the 8th April 1992 from Frazer Nash Cars Ltd Lockeriey Green Garage Romsey Hants anyone know any more ?? Mick |
