Mag Drive Spindle - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Mag Drive Spindle (/showthread.php?tid=4160) |
Mag Drive Spindle - Chris KC - 08-04-2020 I don't know if anyone will find this of interest, but I was reading a review on Amazon of Graham Robson's book "The A-Series Engine: It's First Sixty Years", posted by a gentleman named R.J. Battersby, who in his own words "was an engine designer at Longbridge between 1970 and 1976 and spent a significant period working as a member of the A-Series team." I'll simply quote: "One thing that Robson didn't mention was something I learned when I was modifying the material specification of the A-Series distributor drive spindle (which had a 9 tooth helical gear at one end engaging with the camshaft drive gear and a slotted flange at the other end driving the ignition distributor). I got the original drawing from the drawing stores and noted that it was first drawn in the early 1920s. I then noted that its name had been changed from 'Magneto Drive Spindle'. Yes, this was a part first designed for the 1921 Austin Seven engine and was probably the only part still in production that would fit an engine built almost 50 years before!" RE: Mag Drive Spindle - Charles P - 08-04-2020 Odd though that the magneto drive spindle doesn't have a 9 tooth helical gear. I suspect the author was confusing magneto and distributor or dynamo! RE: Mag Drive Spindle - Zetomagneto - 08-04-2020 Total nonsense, an A series distributor drive spindle is nothing like an Austin Seven mag drive shaft RE: Mag Drive Spindle - Chris KC - 09-04-2020 1970 was a long time ago....of course it's entirely possible an old drawing might have been heavily altered by the time Mr. Battersby saw it. RE: Mag Drive Spindle - Zetomagneto - 09-04-2020 Chris, are you familiar with the A series?, or a Magneto drive.Here is an A series distributor shaft RE: Mag Drive Spindle - Ruairidh Dunford - 09-04-2020 Interesting quote Chris - next thing you know someone will be thinking it was you that said it. |
