Temporary fix & charging advice - Printable Version
+--- Thread: Temporary fix & charging advice (/showthread.php?tid=4124)
Temporary fix & charging advice - David.H - 01-04-2020
I need to retain the overflow pipe on to the radiator header tank. I imagine it was soldered in place through the side wall of the tank. Unfortunately I cannot just pull it out of the tank & plug the hole as there is a lot of pipe inside the header tank and I can't remove it without damaging it.  I Just need to stop it leaking temporarily while I run the engine (and the car) around a bit. The rad will have to come off to do it properly, but what might hold it? Chewing gum, plumbers putty, araldite? I can't clean it up very well as access is not great so araldite probably won't hold. nor would fibreglass resin.
So something a bit better than a bodge!
Annoyingly the ammeter is showing a discharge, the dynamo reads lots of volts across it's terminals and it used to show a charge before I rewired it....where do I start? I suppose the *****switch board will have to come off ...again!
RE: Temporary fix & charging advice - Stumpi - 01-04-2020
Try Leak Fix for a temporary repair its available from wickes,Clean well with White Spirit and smear on liberally.
Quik metal may work as well but if there is any vibration it may fail.
RE: Temporary fix & charging advice - David.H - 01-04-2020
Thanks...I think it does need to be a bit flexible,
D
RE: Temporary fix & charging advice - Hedd_Jones - 01-04-2020
gob it up with silicone. Its twrrible stuff, but sticks like to a blanket, waterproof and vibro proof
RE: Temporary fix & charging advice - Nick Lettington - 01-04-2020
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=https://fernox.com/product/ls-x-external-leak-sealer-50ml/&ved=2ahUKEwiA6ZzLlMjoAhVZiFwKHWbuAs8QFjAAegQIARAB&usg=AOvVaw03vr5YD1GYfF6wH01LWQSb
This is the stuff to use.
Sounds good! ....and you can safely drink the radiator water, it won't contaminate it!
Now to sort out the charging...it has worked since re wiring so it can't be so difficult......................
d
RE: Temporary fix & charging advice - Colin Wilks - 01-04-2020
I think it depends on the size of the hole. The Fernox sealant says it will need some reinforcement if there's much of a gap. Given you say you may not be able to clean right up to the leak point because of access, I'd go with Hedd's suggestion and clart it up with silicone, although I find when using it that it has a nasty habit of sticking to absolutely everything except the bit you want it to.
RE: Temporary fix & charging advice - Nick Lettington - 02-04-2020
The fernox product is I believe a water cured silicone mastic. You need reinforcement for a mains pressure leak, such as a leather patch lathered in ls-x held by a jubilee clip, but unless you have a gaping hole,  it is in my experience ideal.
RE: Temporary fix & charging advice - David.H - 02-04-2020
It is just the 1/4" overflow pie that has come adrift. I have made a bracket to stop it flapping about, so some jollop should stop the serious dribble!
RE: Temporary fix & charging advice - Colin Wilks - 02-04-2020
"Jollop" - another rather apt collective noun!
