Non Seven Hardy Spicer Kit - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Non Seven Hardy Spicer Kit (/showthread.php?tid=4104) |
Non Seven Hardy Spicer Kit - Dave Mann - 30-03-2020 RE: Non Seven Hardy Spicer Kit - Stuart Giles - 30-03-2020 Here's a scan of the relevant page from a UJ manufacturer catalogue I have here. Neapco (the manufacturer) part number on the left. Spicer part number on the right. Bearing diameter is self explanatory. OSR dimension is for circlips being on the outside of the cup. ISR dimension is for circlips being fitted on the inside of the cup (in the groove that yours seem to have) so an external style circlip ends up retaining the cup from the inside of the yoke -this fitting is quite common on American cars and machinery and I can confirm is incredibly fiddly to install ![]() There doesn't seem to be an exact match to yours -Spicer 1310 (a common size on larger cars) is the closest. ![]() RE: Non Seven Hardy Spicer Kit - Dave Mann - 30-03-2020 Many thanks Stuart. |
