CAV DEL type dynamo question - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: CAV DEL type dynamo question (/showthread.php?tid=4102) Pages:
1
2
CAV DEL type dynamo question - Mark McKibbin - 30-03-2020 I am working on my new to me Chummy and the dynamo is a CAV and it looks like a type DEL,
Picture of armature attached RE: CAV DEL type dynamo question - Dave Mann - 30-03-2020 Are the main and third brush boxes insulated from the end plate? RE: CAV DEL type dynamo question - John Mason - 30-03-2020 Hi Mark, when I look at your photo it looks like the gaps between the segments of the commutator where the windings are soldered to it are not clean. This could cause short circuits within the windings. it would do no harm to clean these out (and the gaps on the rest of the com) with a narrow sharp tool such as a pointed knife used upside down so that the sharp edge is facing upwards. John Mason RE: CAV DEL type dynamo question - Bob Culver - 30-03-2020 The two pole armatures are wound 1 to 2 to 3 etc and much can be fathomed with a digital meter which reads very low ohm. The 4 pole advances in steps of several segments and requires more thought to check . RE: CAV DEL type dynamo question - Mark McKibbin - 30-03-2020 (30-03-2020, 09:17 AM)Dave Mann Wrote: Are the main and third brush boxes insulated from the end plate? Yes I have tested, they are open cct to the frame (30-03-2020, 09:30 AM)John Mason Wrote: Hi Mark, when I look at your photo it looks like the gaps between the segments of the commutator where the windings are soldered to it are not clean. This could cause short circuits within the windings. it would do no harm to clean these out (and the gaps on the rest of the com) with a narrow sharp tool such as a pointed knife used upside down so that the sharp edge is facing upwards. I have checked resistance between segments and there is some although not much at about 0.9 ohm (30-03-2020, 10:38 AM)Bob Culver Wrote: The two pole armatures are wound 1 to 2 to 3 etc and much can be fathomed with a digital meter which reads very low ohm. The 4 pole advances in steps of several segments and requires more thought to check . Thanks Bob, With that in mind I will have another look with the multimeter. RE: CAV DEL type dynamo question - John H - 30-03-2020 Correct me if I'm wrong, but I suspect it won't generate unless you supply current to the field winding from a battery via a "warning light" bulb, like you get with the dynamo installed in the car. If you simply spin it on the bench (with nothing else connected), I don't think it will do very much, even if everything is okay? RE: CAV DEL type dynamo question - Mark McKibbin - 30-03-2020 (30-03-2020, 12:00 PM)John H Wrote: Correct me if I'm wrong, but I suspect it won't generate unless you supply current to the field winding from a battery via a "warning light" bulb, like you get with the dynamo installed in the car. If you simply spin it on the bench (with nothing else connected), I don't think it will do very much, even if everything is okay?Yes I have been running it in the car with the lamp connected, on the bench it has been run as a motor with the F and D terminals linked RE: CAV DEL type dynamo question - John Mason - 30-03-2020 Mark, Have you another dynamo that you know is good that you can swap over armatures over with. That way ar least you’re will know if the problem is with the armature. John Mason RE: CAV DEL type dynamo question - Bob Culver - 30-03-2020 Digital voltmeters detect all sorts of stray voltages. Seven dynamos do seem prone to lose magnetisation. Re polarisation is often helpful. It is a long shot but if the field is connected backwards the dynamo generates an output which cancels the field so it will never get going. It is very unlikely the armature is wound wrong . Even if given a bare armature and the wrong one as a pattern I think the comm section numbers is different, and one has armature poles in a slight helix form.. RE: CAV DEL type dynamo question - Mark McKibbin - 30-03-2020 (30-03-2020, 08:27 PM)Bob Culver Wrote: Digital voltmeters detect all sorts of stray voltages. Seven dynamos do seem prone to lose magnetisation. Re polarisation is often helpful. I have found that as well until I bought a good one (Fluke) it is rock solid in an electrically noisy environment like a 7's charging system, I have re polarised it and I assume as I have run it as a motor that would have re polarised it again. (30-03-2020, 01:50 PM)John Mason Wrote: Mark, Have you another dynamo that you know is good that you can swap over armatures over with. That way ar least you’re will know if the problem is with the armature. Good Idea John, That will be on today's list. |
