Weight of rear of Ruby - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Weight of rear of Ruby (/showthread.php?tid=4093) |
Weight of rear of Ruby - Viteran - 29-03-2020 Hi I am needing to work on the rear hub of my Ruby but I wanted to keep it slightly mobile in the garage so I can move it out a little to access behind it occasionally. I have some heavy duty castors in a frame that will support the front axle . I also have some lighter “Clarke” castors that are rated at 72kg each that I can make a frame to support the rear/ rear axle. The question is how heavy is the rear of a Ruby.The kerb weight is down as 616kg and I would think about 2/3rd of the weight is at the front so a “ guesstimate” rear weight of about 210kg and the castors would support 288kg, so should be ok. Any advice? ( by the way the supports would be backed up with axle stands except when I actually move the car) Ian RE: Weight of rear of Ruby - JonE - 29-03-2020 try it? its's not really going to endanger anything, is it, other than a castor being prematurely retired? RE: Weight of rear of Ruby - AustinWood - 29-03-2020 I weighed my fabric saloon using bathroom scales. One wheel at a time with a similar thickness spacer under the other wheel of each axle. Total came out at about 10cwt including all the junk I carry around. RE: Weight of rear of Ruby - Viteran - 29-03-2020 I was going to see how things went as jonE said the worst scenario is the castors break and anyway if they are rated at 72kg I am sure there is some leeway written into that. Didn’t get round to it today as it has gone cold, even had sleet this morning, not rally a garage day. RE: Weight of rear of Ruby - John Mason - 29-03-2020 I move my Ruby around in and out of the garage on a trolly jack put under the diff with a folded piece of rag between diff and jack. I then put axle stands underneath whilst working. John Mason RE: Weight of rear of Ruby - Colin Morgan - 29-03-2020 Could meaure using a set of bathroom scales (25 stone = 160kg) under a front or rear wheel? Easy then to work out weight on each wheel, if total is 613Kg? RE: Weight of rear of Ruby - GK5268 - 30-03-2020 When I took my Ruby in for a voluntary MoT, August 2018, when it was sat on the rolling road, with a driver on board, the weight was displayed for each axle and rear of the car weighed quite a bit more than the front of the car, which was surprising, I can't quite remember what the actual split was, but I guess the tester was probably around 60-70Kg and with that I estimated that the car weighed in at around 480Kg total, with the uneven split front/rear, I would have thought at each rear wheel it would be about 130Kg so your figures are about right. |
