DK4A distributor service replacements - Printable Version
+--- Thread: DK4A distributor service replacements (/showthread.php?tid=4086)
DK4A distributor service replacements - JonE - 27-03-2020
I came across an old Barry Riseley post on distributors, where he referred to theĀ
"Service replacement distributors were lablelled either Service No's 400206 or 40224/S. (and I think the different numbers simply reflect a change in the Lucas numbering system, rather than a change in Distributor characteristics).It is interesting to note that these later types were also specified for a range of other Austin cars of the 1930's (were supplied without clamp plate and drive gear)"
I have found a 40224 A which I think may be sameĀ but from an Austin 8 or 10 - manufactured 1951. No drive gear or drilling. Does anyone know what the difference in characteristics are? It looks absolutely identical but I haven't started to strip it yet.
RE: DK4A distributor service replacements - Chris KC - 27-03-2020
.jpg   DK4.JPG (Size: 82.77 KB / Downloads: 222)
Looking at the specs here (below) I would venture that the /S was a vacuum advance unit (those 2 additional part numbers are for vac advance unit & bracket) - otherwise identical. An 'A' suffix usually stands for 'auto advance'.
The 40224 or 40224/S was specified as a service replacement for a number of different parts of similar specification, most likely they differ in drive gear fitting details but highly likely they can be made to fit a Seven.
.jpg   Capture.JPG (Size: 9.77 KB / Downloads: 210)
.jpg   Capture1.JPG (Size: 35.37 KB / Downloads: 210)
RE: DK4A distributor service replacements - JonE - 27-03-2020
very interesting Chris - so perhaps Barry's 2006 post was a little bit wrong. The chap on ebay had misread the code (or at least completely misquoted it) but fortunately the picture on the side of the unit revealed.
The 7-8.5 degrees is presumably a wider catch-all, or a more rigorous appraisal of their action, 15 years further on...
Any advice on drilling for end gear? I was thinking it would be possible using an old gear as a guide, but is an easy enough job or an engineers one?
.jpg   Capture1.JPG (Size: 65.07 KB / Downloads: 180)
I would personally not attempt it without a vee block and a decent bench drill and a nice sharp drill bit, but I happen to have those things! There's quite a high risk of not going through quite straight.
RE: DK4A distributor service replacements - JonE - 28-03-2020
Brilliant - I shall make a V block and buy a new bit - I've got the pillar drill.
thankyou.
