Unknown piston set - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Unknown piston set (/showthread.php?tid=3947) |
Unknown piston set - Parazine - 26-02-2020 Guys, I need some help. I recently came across a set of 4 cast iron pistons. They are slightly bigger than A7 pistons but they carry a scripted "Austin" logo on the top and the part number 1A1934. Dimensions are as follows: Diameter: 2.2635, oval, split skirt, down to 2.2632 (on the skirt) Rings: 2 compression, 3/32", 1 oil control, 1/8" Gudgeon pin: 1/2" dia. Height of crown above gudgeon pin: 1 1/4" I was going to put these on FleaBay but I (unlike many sellers it seems), like to know exactly what it is that I'm supposed to be selling! Can anyone help by identifying them? They're not Big 7 (unless oversize) and probably came from and industrial engine I should think. Regards Tim Reynolds RE: Unknown piston set - Stuart Giles - 26-02-2020 Beresford Stork fire pump? they would be a .030" oversize piston for the Austin Eight motor though. RE: Unknown piston set - A G Wood - 27-02-2020 They may be aftermarket replacements, although there would surely be trademark issues? According to Oldhams Press 'Practical Automobile Engineering Illustrated' (circa 1955): "the practice of replacing aluminium pistons by cast iron ones on light commercial vans or travellers' cars is sometimes adopted. This is done with a view to obtaining a much greater mileage, not possible with aluminium pistons, before cylinder reconditioning is again necessary..." RE: Unknown piston set - Bob Culver - 27-02-2020 Hi AG It seems a curious statement as virtually no wear of the piston surface or bore below the rings occurs. Perhaps in an era where most pistons were fully split skirt and nearly all closed up in use, a solid piston gave better service. Maybe with the old oils and poor air cleaners skirt wear was significant. The Chev 6 to the 50s was one of the last cars with iron pistons. RE: Unknown piston set - Chris KC - 27-02-2020 I wouldn't want to rev that too hard. |
