25 Stud Head water jacket ? - Printable Version
+--- Thread: 25 Stud Head water jacket ? (/showthread.php?tid=3904)
25 Stud Head water jacket ? - stevenm - 15-02-2020
Does anyone know if the 25 stud head had a water jacket or was just a big dirty blanking plate of a a cylinder head ?
[Image: 5350251744-e62bb1b11d-o.jpg]
RE: 25 Stud Head water jacket ? - Mike Costigan - 15-02-2020
That's a Jamieson 32-stud engine; both 25-stud and 32-stud engines still had conventional water jacketing (note the standard block side-manifold and the top manifold on the side of the head, above inlet & exhaust manifolds, which connects to the bottle header tank).
Edit: 25-stud head gasket:
RE: 25 Stud Head water jacket ? - stevenm - 16-02-2020
Thank you !
Incredible bit of work.
