Banging from rear end 1932 RP. - Printable Version
+--- Thread: Banging from rear end 1932 RP. (/showthread.php?tid=387)
Banging from rear end 1932 RP. - Smiley - 28-10-2017
Hi everyone,  I have recently been experiencing a banging under the rear end of Smiley when hitting pot hole.  I have looked underneath but can't see anything obvious.
Does anyone have any idea where I might look next. ?
RE: Banging from rear end 1932 RP. - Ian Williams - 28-10-2017
Torque tube anchor?
RE: Banging from rear end 1932 RP. - Smiley - 28-10-2017
(28-10-2017, 09:01 PM)Ian Williams Wrote: Torque tube anchor?
Hi Ian, Thanks for the info.  I'll check that out and let you know how I get on.
RE: Banging from rear end 1932 RP. - Bob Culver - 29-10-2017
Hi Smiley and others
If you could please give more details then many may learn from the experience.” Banging” could be a myriad things.
If you can get someone to vigorously rock and bounce the car much can be explored. Loose s.a links etc.
And someone letting in clutch forward and reverse whilst from a safe side position you listen and observe underneath or through the driveshaft cover plate.
