SU carb leaking - Printable Version
+--- Thread: SU carb leaking (/showthread.php?tid=3869)
SU carb leaking - Tatenlyle - 06-02-2020
I bought an SU carb last year, and fitted it to my RP with an adaptor. When I turned it over, it leaked petrol from the vent. So I bought a new needle valve and seat from Burlens, it still shoots petrol out. Do I need to fit an electric pump, and if so, what type
RE: SU carb leaking - Stumpi - 06-02-2020
A friend recently had this problem on a 70's Midget[1 1/8su].We eventually realized the vent hole had been enlarged,this was filled with solder and a .030 hole drilled which solved the problem.
The vent hole on this carb is just below inlet and there should be a small plate covering it which is held on by the flexible fuel pipe.
Andy
RE: SU carb leaking - Nigel Ricardo - 06-02-2020
Are you using a Seven Workshop fuel pump?
RE: SU carb leaking - Tatenlyle - 06-02-2020
No, it's an original, works fine with the solex. The carb is an H1, with the vent below the brass screw which holds the top on
