A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO (/showthread.php?tid=3749) |
A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO - Steve Bryant - 12-01-2020 A Modern Lip Seal for the 1 1/8” crank A7 Engine
Part two
Machining the seal holder: Aluminum was purchased in the form of a slice of six inch diameter rod. I scribed the outer diameter of the seal holder on it and cut off the excess on the band saw so I wouldn’t have to machine it all off (and also so the blank would fit in my lathe).
5 ALUMINUM BLANK.jpg (Size: 34.02 KB / Downloads: 323) Since the most important dimension was the one the seal pressed into this was machined first. The dimension for the hole was actually written on the seal which was 2.500” but the actual seal measured .005 larger than that as it is designed to compress and be a tight fit. I opted to make the hole about .002” larger so that I could press the seal in with my fingers rather than using a press or hammer as I didn’t want to distort the holder when installing the seal. The rest of the dimensions were standard turning procedures. The most difficult thing was holding the seal holder which required changing chuck jaws so things had to be checked with a dial test indicator to ensure concentricity. A groove was machined in the portion that locates into the bearing holder to take a small section O-Ring to seal the seal holder against oil seepage. A thin paper gasket could be used between the seal holder flange and the bearing holder but the O-Ring should render that redundant. The four bolt holes were drilled using the bearing holder to locate them by poking the same size drill as the bearing holder hole down each hole to drill through the seal holder flange.
Once installed my calculations show that there should be about 1/16” clearance between the flywheel and the retainer bolts etc.
6A SEAL HOLDER COMPONENTS.JPG (Size: 35.64 KB / Downloads: 324) 6B ASSEMBLED HOLDER BOTH SIDES.jpg (Size: 35.52 KB / Downloads: 323) 6C DEPTH GAUGE .JPG (Size: 45.86 KB / Downloads: 323) 6D HOLDER IN PLACE.JPG (Size: 39.25 KB / Downloads: 323) 7 CLEARANCE.JPG (Size: 37.16 KB / Downloads: 323) I’m hoping this will function as well as the other fly wheel seal
that is sold for the I 5/16” crank.
I have not yet drawn up a mechanical drawing but hope to soon for those wishing to make a seal holder for themselves.
Stephen
RE: A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO - Tony Press - 12-01-2020 Excellent work - Herbert would be proud ! If successful it might need mass production RE: A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO - steve davidson - 12-01-2020 I thought that a unit could be purchased but what you've done is beautiful, congrats RE: A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO - AustinWood - 12-01-2020 I fitted a lip seal using parts supplied by David Cochrane of A7Components. However I don't think he any longer lists the plate for 1-1/8" crank. RE: A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO - David Cochrane - 13-01-2020 Although the modern lip seal plate is shown as 1929-39, it can be fitted to the 1-1/8" engine by machining a recess in the back of the rear main bearing housing. Then use the BB7a lip seal. David RE: A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO - Steve Bryant - 13-01-2020 David, the reason I went to all this trouble is so that I didn't have to machine the back of the rear main bearing housing, but I appreciate what you are saying. Thanks for the information. Stephen RE: A Modern Lip Seal for the 1 1/8” crank A7 Engine PART TWO - AustinWood - 13-01-2020 The machining of the rear main housing needed is minimal. |
