Changed plans (we've nearly all been there...) - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Changed plans (we've nearly all been there...) (/showthread.php?tid=3672) |
Changed plans (we've nearly all been there...) - Tony Griffiths - 23-12-2019 Changed plans - RE: Changed plans (we've nearly all been there...) - Tony Betts - 23-12-2019 Love the cat mascot. Tony. RE: Changed plans (we've nearly all been there...) - Ian Dunford - 23-12-2019 Shaved his beard off to save weight in the same way you used to lower the level of your Chummies back axle oil it seems Tony G? RE: Changed plans (we've nearly all been there...) - Tony Griffiths - 23-12-2019 (23-12-2019, 06:29 PM)Ian Dunford Wrote: Shaved his beard off to save weight in the same way you used to lower the level of your Chummies back axle oil it seems Tony G?'twas only a rumour Ian that I used a teaspoon full of 3-in-1 (it was actually two). |
