offset 19 inch austin inscripted wheel - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: offset 19 inch austin inscripted wheel (/showthread.php?tid=3613) |
offset 19 inch austin inscripted wheel - Dellie - 06-12-2019 Hello all, I'm busy with renewing the spokes on my 19 inch wheels Austin Scripted wheels (closed center). But I was to enthusiastic and forgot to measure the offset of the wheels. Does anybody has the dimensions? Or be so kind to measure it? With kind regards Pieter RE: offset 19 inch austin inscripted wheel - Howard Wright - 06-12-2019 Hi Pieter I think that the wheel centre and rim should lie flat ie. no offset. However I have read somewhere that you can offset the rear wheels if you have clearance problems. I’ve done this with the new special wheels but only 3/8” Cheers Howard RE: offset 19 inch austin inscripted wheel - Dellie - 06-12-2019 Hello Howard, Thank you for the quick response. With kind regards Pieter RE: offset 19 inch austin inscripted wheel - Barry Townsend - 06-12-2019 When I did mine the rim and the hub were flat |
