Silly Starter Motor Question - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Silly Starter Motor Question (/showthread.php?tid=3386) Pages:
1
2
Silly Starter Motor Question - John P - 06-10-2019 Hi, Just fitting a starter motor to my Ulster replica (forward facing starter) and can't decide which way the terminal post should be. It will either be vertically up or down but which is correct? Upwards would probably make it easier to connect but the cable would have to run up over the motor and also the terminal would be quite exposed to damage and the elements. Any advice, John. RE: Silly Starter Motor Question - Robert Leigh - 06-10-2019 The terminal normally faces upwards. Robert Leigh RE: Silly Starter Motor Question - John P - 06-10-2019 Thanks, Just fitted it with the terminal on top as suggested. (In fact, when I offered it, it looked as though it probably wouldn't have fitted with the terminal at the bottom). John. RE: Silly Starter Motor Question - Reckless Rat - 06-10-2019 It's a good idea to run an earth cable from the lower starter mounting bolt direct to the earth on the battery. Whilst the frame/chassis/engine should all be earthed, the starter takes a lot of current and it needs the best feed it can get, especially if you're still on 6 volts. RE: Silly Starter Motor Question - Robert Foreman - 06-10-2019 Originally the rear mounted starter motor was fitted with the terminal underneath. Then a straight cable run from battery to motor. RE: Silly Starter Motor Question - Hedd_Jones - 06-10-2019 my two are fitted terminal down RE: Silly Starter Motor Question - Ruairidh Dunford - 06-10-2019 Likewise... RE: Silly Starter Motor Question - Steve Bryant - 12-10-2019 Mine is just Terminal ! Stephen RE: Silly Starter Motor Question - Reckless Rat - 12-10-2019 For those of us that are still on 6 volts there is a huge benefit on having both earth and live feed connected direct from the starter motor to battery. Prior to doing this, the starter on my RP would work, but albeit reluctantly even though I had an extra earth cable connected to one of the head studs. When I relocated it to the lower starter motor fixing bolt the motor now spins like a good 'un even for cold starts where it needs a good spin to prime the carb. A mod more than well worth it. It seems that some conductivity is lost through the block/crankcase interface and even the timing case to chassis earth strap doesn't help that much. RE: Silly Starter Motor Question - Chris Garner - 12-10-2019 Sorry to be a bit of a pedant but the correct terminology for starter motors fitted up to September 32 is forward facing, after this date they are rear facing. |
