Dynanometer Testing - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Dynanometer Testing (/showthread.php?tid=3245) |
Dynanometer Testing - Martin Baker - 28-08-2019 Has anyone any recommendations for a dynanometer tester who can help get my carb jetting and ignition timing spot-on? Preferably somewhere not too far from Basingstoke. RE: Dynanometer Testing - Zetomagneto - 28-08-2019 Sigma Engineering, Gillingham, Dorset RE: Dynanometer Testing - Dave Mann - 29-08-2019 I have a friend who put his Seven on a rolling road dynamometer in Lancashire and had the following results: 28 HP at 4400RPM at the engine, 20 HP the rear wheels and 74 MPH on 500 x 15" tyres. Can anybody explain how they got the engine power without a torsion meter between engine and gearbox. RE: Dynanometer Testing - Mike - 29-08-2019 In the past Pigsty were extremely helpful!! RE: Dynanometer Testing - Colin Reed - 29-08-2019 HI Dave, Short answer, There is NO way It can only be an educated guess . Colin NZ RE: Dynanometer Testing - Alan - 29-08-2019 Well if you have a really good rolling road, you can use the rollers to drive the transmission in neutral to get the rolling losses, but I doubt they have that possibility. |
