Slight kick back on the starting handle - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Slight kick back on the starting handle (/showthread.php?tid=3193) |
Slight kick back on the starting handle - John Mason - 09-08-2019 I recently had occasion to to remove the distributor on my Ruby which obviously meant I had to re time the ignition. This I did using the 1/4 marking on the flywheel to establish TDC on no1 cylinder. Then adjusted the dizzy with the aid of a bulb fixed between the low tension and Earth. I started the engine then fine tuned things by ear until the engine ran and sounded smooth. The car now runs and starts well however when starting on the handle there is quite a kick back from compression not because the engine has fired. This is until you get past TDC. IS THIS NORMAL. John Mason. RE: Slight kick back on the starting handle - "Slack Alice" Simon - 09-08-2019 I would retard the ignition until it doesn't kick back - or is just a little kick. A big kick indicates too much advance. Both my cars have manual advance, so it is easy to do, and easy to replicate the kick back situation just to get a feel for it. But if you are sure it is running smoothly and not sounding over advanced then don't worry too much. RE: Slight kick back on the starting handle - Colin Morgan - 09-08-2019 A kick - where the starting handle flicks back strongly or weakly occurs when the spark fires. With the timing as set on my Ruby, I can feel a weak kick as I turn the engine over slowly every half turn as the cylinders fire in turn - I think because the handle is turned gently, giving a low compression at ignition, the kick is slight. Once, when I had the ignition too far advanced during setting, I pulled the handle quickly to start the engine, it kicked back hard and ripped the handle out of my hand. Obviously, the other force felt on the handle is the compression force from each cylinder as the engine is rotated - this is not so strong on my car - other engines I have owned have had much more compression, but this is a steady build up as each piston on compression rises in turn and separate from any 'kick'. Colin RE: Slight kick back on the starting handle - John Mason - 09-08-2019 Thank you both for your advice. Simon my distributor turns clockwise which way do I turn it to retard the engine. John Mason RE: Slight kick back on the starting handle - David Stepney - 09-08-2019 Clockwise. RE: Slight kick back on the starting handle - Bob Culver - 09-08-2019 As a matter of interest which distributor? The early one marked 3 deg would seem more liable than the later 8 deg. Always assuming the advance (retard) mechanism is working. The static settings for the two distributors were coverd ina a recent post. Kickback on larger cars can be dangerous. The rule was to pull up only and to keep fingers and thumb on the same side. Some Model T fanatics reckon only the left hand should be used! |
